What couple possibly cause this? Yesterday, it would leak from behind the pulleys as I was pouring it in the radiator, went 5 miles, then overheated. Today, I topped it off after again getting it a little too hot, and it ran the rest of the day with only a few drips.
Do I have to pull the engine to change the pump?
Also, its leaking a LOT of oil, but only when I top it off. It sprays all over the engine compartment, bad as I've ever seen, then seems to level off. Trouble is, the oil light keeps coming on in corners.
