Rocker panel repair?
  • Rocker panel repair?
    I looked around real quick, I didn't see a whole lot on the subject. I went and looked at a festy yesterday, build date of 1990 - not sure which model. My main concern were the rocker panels seemed to be pretty rusted out, and without pulling it out I can't inspect the floors. I only got a brief look at it. Not sure if it will be worth my time, but figured I'd ask here.
    The doors & floor aren't really a concern to me, but the rockers are - what have you guys done to fix them? Welding isn't an issue for me - would I be looking at cutting some from a junkyard car, and welding them in? or would sheet metal work? What are your fixes?
    Thanks
    -Rocket
    1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
    Rocketchips!
    Bolt-on Weber Carb Adapters!
    interested, i have this problem too
    06 Jeep Cherokee Overland
    95 Aspire (sold)
      well in junk hard around here its hard to find good panels so I just used my race car to make fiberglass molds with matte and resin but sheet metal would be the right way I just don't have a welder that will weld sheet metal , I would start at the pinch weld clamp it and then bend it around to weld, the good thing is that you can get to the inside to undercoat the back side for future rust prevention... but cutting good panels from another car would be easiest.
        I've seen many rust-free festys in Harry's hazleton for some reason, but cutting rockers out would be a problem. I'd need a battery powered sawzall
        Rocketchips!
          sawsall isn't the issue, it's welding the 4 layers back in place to maintain structural rigidity. if you want picks of what the inside/cross section looks like, i have some from my strip party.
            Easiest- bondo+fiberglass
            Easy- cut off donor car, tack weld, bondo
            harder- grind, cut, tack weld new sheet metal, and bondo
            hardest- Cut, bend, weld, and bondo all layers in place.
            1st 2 options will suffice if paired with some other cross-bracing of the unibody. (Cage, anyone?)
            1990 White L-Plus 5-speed rust-machine
            Scrapped
            1991 Blue L 5-speed
            daily driver, intermittent project
            1993 rustless wonder
            A shell, awaiting suspension, brakes, and B6T
              Having done both your first two options, I would definitely say you have the two reversed
              89SX funtop! Fully loaded!
              RIP 90LX
                yeah.... no.
                you forget the rocker is STRUCTURAL. it must be welded in and ALL of the rot removed/replaced with new metal for things to be right again.
                  Yes totally structural.There is way more going on inside the rockers than what appears. In order to do them correctly its a VERY busy job. I was really surprised to see the metal channels that are inside them. I just figured they where hollow rockers. Then I got educated.
