A few of you might remember me from my few novice posts trying to resurrect a 1990 L-Plus Auto.
Since I've started, I've done the following:
Replaced tank with used
Cap, rotor, plug, wires
Wheel bearings x 2 (front-right twice now.. more on this later)
Both rear hubs
Oil change, half of a tune-up
New tires
$439.39 front end work, including:
Both ball joints
Tie rod ends
FR CV axle
somethings else I just don't remember
New o2 sensor
Now after all this, plus $250 for the car and about $1300 invested so far..
Heard a droning noise once again, took to our mechanic..
Back-left wheel bearing scored nearly away (can't torque properly because someone put in a cotter pin [or whatever the 93s had on them, I can't remember the exact terminology] at some point, at an odd angle), front-right drones at transmission side, to what he can tell (without taking the whole side apart again).
One of the rear hubs is already stripped again, needs a front-right.
What do I do now?
I know this is probably in the wrong section, but I wasn't sure where to put it.
I'm out of money, working minimum-wage, trying to keep our heads above water.
He says sell it and find something else. The problem is, I truly don't want to sell it, and don't know if I could get the money I've put into it back out of it. It rides nicely down the road, aside from the noise.. has brake issues I was planning on fixing later (master cyl.), and I just plain love the car.
What do I do?
~Spike
Both rear hubs
New tires
Both ball joints
Tie rod ends
FR CV axle
New o2 sensor
What do I do now?
What do I do?
~Spike
