Didn't think it was possible... 26 MPG in a Festiva...
  • Didn't think it was possible... 26 MPG in a Festiva...
    WHAT GIVES!!!!! I was averaging a hair over 40 in June, and it has been steadily dropping ever since. Click my Fuelly link for the stats.
    I DON'T UNDERSTAND!!!! Last fill-up was the worst YET, 26 mpg.
    Right before it stopped running, it was running better than it ever had in my ownership. Then I finally get it running again.... and it runs fine, but just not quite like it did.... I may even be imagining things, it could be back to the same, I just got used to the Grand Prix's power over those two weeks. I don't know.
    So... What should I be looking for?
    Buck.
    -1993 Ford Festiva GL, ~200k, B6, Aspire rear, Rio front, 5-speed. '87 Prelude alloys. Happy to be back on the route!!!
    -1999 Toyota Sienna XLE, 346,000
    -1996 Chevrolet K1500 Z71, 350 V8, 198k, hauler
    have you filled up on several gas stations?
      Is it running strange like not wanting to run after warmed up? Mine was getting bad mileage like that when I bought it and it was the coolant temp sensor but it was running a little erratic too.
      1993 Festiva GL The Besty Festy
        spark plugs? timming? maybe its time for a mayor tuneup!
          I do better than that hauling firewood !!
            If the check engine light is not on, then the computer thinks the engine needs the extra fuel. The coolant and air temp sensors if not completely failed can cause this with no check engine light. Slow but not failed o2 can also be a false normal. Might check your odometer just to make sure your math is right!
              What did you do to "get it running again"?
                My first guess is O2 sensor failing. Second guess would be cat getting clogged. Swap the O2 with a new Nippondenso unit, see if that helps.
                  Yes
                  Runs fine all the time
                  ECM from Festiva2
                  Buck.
                    Ouch. Is there a hole in your tank? I know the feeling going back n forth between the festiva n a gp, I wish I could fill up my tripod. Plus it doesnt help with th speedo cable broke too.
                    NTRCOOL
                    1990 ASC/McLaren Turbo Grand Prix x2
                    1989 ASC/McLaren Turbo Grand Prix
                    1990 Cadillac Fleet-wood Brougham
                    1987 Buick LeSabere T-Type
                    1980 Oldsmobile Ninety Eight Regency coupe
                    1977 Chevrolet Caprice Classic Aeroback coupe
                      Mine seems to run fine and it's only getting 28mpg.
                        The best I can get in my Festiva is ~30mpg and I wander why :lol:
                          Something must be wrong though, I was averaging over 40 with almost identical driving earlier. I guess my first step is a full rotor/cap/wire/spark plug change.
                          Buck.
                            I'd say you have a pretty good excuse LOL
                            Buck.
                              :lol:
