hey my 97 aspire check engine light just came back on after i had both 02 sensors replaced in the last 3 days. i could not pass emmisions cause the downstream one was busted so i replaced it this morning the check engine light came back on an i replaced the front one got the light off drove around and it came on again... whats the problem an how do i fix it asap....
p.s. my reg is up in 6 days....
Frankie
fully custom 88 festy (project doomsday) Febuary in 2012 calander
Blockspire: ken block replica aspire
AdvancedDynamix: "If you put the same kind of effort into your engine that you put into the rest of the car, well... it'll be epic". thanks man
If it is an obd-2 car it will be easy to check what is wrong with it. If you have an advance auto parts or simalar around you have them run the codes and it will tell you whats wrong. Then go from there.
93 Festiva L White B6T
99 Dodge Ram STL Green Cummins. AKA the Jolly Green Giant
89 Festiva Blue
91 Green “Mad Maxine” Festiva B6T
93 Festiva GL Black BP automatic
93 Festiva GL Green stock
Most of the time a parts store will pull the codes for free. If there is more than one have them clear all codes, then drive it till the light comes back on, go straight there and get that code. If again there is more than one write them down in the order they are listed, most important codes are listed first.
