Before I start; I've read about the 2stage t-stat. I don't think I fall into this category.
The heater will not blow heat (at all).
Here is what all I've done/checked. Made sure coolant lvl was up and that there was no air in the system. Let it run till it was warm (about a third of the way on the temp guage inside) and checked the 2 hoses (1 going in and 1 going out) to the heater core and they were both hot. Checked the switches (climate) inside to make sure they were moving the appropriate parts underneath the dash, and they were.
If the 2 hoses into the firewall (heater core) are hot then it shouldn't matter on the t-stat, the heater should be blowing hot air right?
Or is it still not getting hot enough for the heater to work?
sorry for the redundant post on heater issues.
Any help would be appreciated!!
