One common issue we have with our cars is that the e-brake stops working. The most common cause of this is the e-brake lever seizing up. Solutions have been described well many times but I thought a photo might help.
This is the passenger side e-brake lever from an Aspire. The Festiva one is similar and the driver's side version is a mirror image. The only part of the lever that can be seen without taking anything apart is where the clevis pin attaches. Everything below the black line in the photo is inside the brake assembly. Sometimes the clevis pin will seize into the lever and cause problems but most of the time it's the hinge point inside the brake assembly that does so.
I've found the best way to remedy the problem is to remove the lever, which requires disassembling the brakes, and soaking the siezed joint in a product such as PB Blaster or ReleaseAll. While it's soaking work the joint back and forth, which may require some persuasion. Once it's loose, clean the area as best as you can with a stiff brush. When that's done I use brake grease and work it into the joint and then reinstall.
I hope this proves helpful.
