Two Questions
  • Two Questions
    First question, is this bend normal/ will it hurt anything
    Second question
    I was trying to check the transmission fluid and i understand it has to go to the top line. I didnt see any lines could someone point out the right place to me?
    Also it smells alot like gear oil i have been reading to put ATF in it. Being that i am reaching 180000 here by the end of the month I would like to know what your opinions are on what to put in it
    On a completely unrelated topic, I HEARD ERICAS HEART BEAT AND IT WAS THE COOLEST THING EVER!!!!!!!!! A friend of mine showed me the screwdriver trick!
    06 Jeep Cherokee Overland
    95 Aspire (sold)
    the lines are on the end of your speedo cable
    Rod
    "Confidence is the most important thing you can teach someone... if you can teach them confidence, you don't have to teach them anything else."
    1992 truckiva
    1989 festiva lx (mine again)
    1980 triumph tr7 convertible (project)
    1976 tr7 hardtop (parts car)
    1989 dodge caravan turbo
    1975 amc gremlin 4x4 (play toy)
      oh so the case is needs to be full full then? it went about 3/4 up on the speedo gear i showed you.
      95 Aspire (sold)
        Third question: how do I post the photos? (copy the IMG code)
        Oscar
          By the way, I can see the level mark on the speedo gear shaft.
          Oscar
            roadkyll said on the end of the speedo cable and you said on the gear....
            95 Aspire (sold)
              It's supposed to be up to the tips of those protrusions but I just fill mine to within an inch of the top. That bend in the sheet metal piece is nothing.
                ok thanks, im just trying to figure out where all this gunk came from... oil is fine brake fluid is fine the transmission fluid may be a little load but thats still a lot of crap.
                95 Aspire (sold)
                  i was told the end of the cable but that mark on the gear housing looks like its in about the right spot
                  Rod
                  1992 truckiva
                    I have no idea how he measures the tranny fluid with the speedo cable. Maybe he can enlighten us.
                    Oscar
                      [QUOTE=perucho;478318]By the way, I can see the level mark on the speedo gear shaft.
                      thats what i thought but there was a mark on the other side too thanks alot
                      95 Aspire (sold)
                        same
                        I have the same question where to fill to and what fluid do u use in the manual tranny
                          I just keep the tranny fluid about an inch from top of the speedo hole, kind of a pain dipping the speedo gear in and out to check the marks which are about an inch from the top surface of the trans.
                            This picture is the correct way. Or you can drain an E series & put exactly 80 fluid oz in. I've done this three times now & its spot on everytime. No more pulling the plug & trying to read fluid thats almost invisible. 80 oz.....
                              fluid
                              What type of tranny oil for a manual trans
