G5mr transmission fluid
  • G5mr transmission fluid
    What is the correct fluid to use? I used Dex/Merc ATF last time and want to make sure this wasn't a factor in my tranny dying. It died from the diff pin coming out so i'm thinking it's not fluid related.
    91 Festiva BP Autocross/Track/Rallycross hopeful
    14 C7 Z51
    //what made the pin spin in the first place??
      Much much abuse. Weekly drag racing.
      14 C7 Z51
        some guys on the escort site just run 5w30, some syncromesh, i used half and half all the guys on the feoa site say it ok
        -90 festiva - bp swap "relentless" (thanks matt) aspire swap, pacesetter, underdrive pulley
        -90 festiva - surf blue (undetermined destiny) wanna keep but wifey says noooooooo
          i use merc/dex atf
            Alright, I guess i'm all good. Thanks guys
            14 C7 Z51
              try some syncromesh.
              I swear by this stuff... it completely eliminated my 323 gtx awd's grinds over night.
                I run 80W90 gear oil. The ATF is too thin IMO especially for summer driving.
                I've heard really good things about synchromesh but I haven't run it myself.
                IMHO - if you abuse the diff the pin will come out no matter what fluid
                1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
                Rocketchips!
                Bolt-on Weber Carb Adapters!
                  I use dex/merc atf Ive had 3 trannys stuck in gear that were all running gear oil when I got them so this is why I use atf never had a problem.
                  93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
                  RIP_90 LuX http://www.fordfestiva.com/forums/sh...ad.php?t=32249
                  RIP 88 LX / B8-MEhttp://www.fordfestiva.com/forums/sh...ad.php?t=26398
                  RJ
                    Dex 3 and power punch gear additive
                    Next change probably will be
                    Valvoline Max Life ATF.
                      I switched to Redline ATF+4 in my 90 Taurus SHO because of grinding in 2nd and 3rd with petro based ATF and it totally eliminated the grinding. Redline is some good stuff!
                      Semper Fi til I die!
                      1993 Fescort GT 1.8 BP automatic Kia Rio front struts and cut springs Cut Front Festiva springs with Monroe Aspire struts in rear
                        I'm also pretty curious about this, I decided to go with some thicker stuff with my F series, hope I didn't make the wrong decision.
                        1991 blue L, 5 speed.
                        1988 red L-plus-all stock.
