does the engine have to be warmed up? I bought a compression tester gauge/hose yesterday and I want to play with my b3 before I take it out.. I did it cold and it reads 175 all the way across.
quick question on compression tests
2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
"If it moves, grease it, if it don't, paint it, and if it ain't broke don't fix it!"Tags: None
eh i'm bored so I'll go ahead and put stuff back together enough to get it warmed up, thanks.2008 Kia Rio- new beater
No, that was just removing all the spark plugs and doing 1 cyl at a time cranking it over, i've got it about warmed up now, should I let it run and pulg the gauge in 1 cyl at a time?2008 Kia Rio- new beater
You should remove all 4 spark plugs so the engine can rotate freely, and disconnect the fuel injectors so it isn't injecting fuel. Then do the test with the throttle at WOT1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
That term, WOT, is something I don't understand, I've seen it many times and still don't know what it means.
Wide open throttle? >.<Last edited by zoom zoom; 01-11-2012, 02:49 PM.2008 Kia Rio- new beater
It's a 94 aspire, I pulled the egi inj 30A fuse out in the engine compartment, the results are in, 176/174/176/175
This is after being completely warmed up and long enough to recharge the battery (i used a diff battery to get it started) from 9v to 12.76, the reading @ the battery while running was 14.47v
The engine has 165-170k miles, so I guess it's in pretty good shape for it's age?2008 Kia Rio- new beater
I'd say so!!!1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
yah, if only it made another 150 hp I wouldn't have to swap it! It's intimidating looking at the engine bay now, I'm labeling and disconnecting wires and I don't think I'll even be able to re use the harness for a bp, but who knows, this is just going to be a learning experience. Hopefully I can get everything disconnected, maybe even pull the motor tonight?2008 Kia Rio- new beater
it should only need a few pins swaped at the ECU harness connector and re-route the injector harness... you can even use the aspire MAF if you get the right ECU.Trees aren't kind to me...
Your compression results are really nice. Another informative trick is to compare a 'wet' and 'dry' compression test. This gives you some idea of how good the piston rings are. Test the cylinders as is and then once again with a squirt of oil down the spark plug holes. If the numbers don't change the rings are in great shape.
