Cold today, 0 deg F (-20 C). Starter turned over a few times then just a slow grind. Battery too low or maybe too cold or both.
1. I plugged in the 6 amp battery charger. It has an ammeter. The charging current jumped to 2 amp. After 15 min the current had fallen to 1 amp. After 1/2 hr the current had dropped to nothing as near as I could tell from the needle. The car started. I know I need to get the battery tested. I don't need the car and can wait until the weather warms up in a couple of days.
Does the charging current indicate this battery will not take a full charge any more?
Would it be advisable to leave the charger on over night?
2. This was my backup battery which I put in the car last spring when the old one died. While this battery sat in the garage I would put the charger on it once a month. The charging current would start at 2amp but within minutes fall below 1amp. I assmed that meant it was fully charged.
Was I wrong in assuming it was fully charged when the charging amps dropped below 1?
What is the normal reading on charging amps?
I've looked at my car owner books and searched the Internet without finding enlightenment on the above current questions. Thanks.
