Buzzer Won't Go Off LOL
  • Buzzer Won't Go Off LOL
    I'm sure what happened but my buzzer won't stop going off. When I pull the key it turns off but when driving it's constantly on. Anyway to disable the buzzer completely?
    Unplug it, feel around under the dash when it's buzzing to unplug it, sometimes the plug is stiff.
    Owner of:
    In progress:
      I unplugged mine. It is a little white clip near all the plugs for the ignition switch.
      93 Festiva L White B6T
      99 Dodge Ram STL Green Cummins. AKA the Jolly Green Giant
      89 Festiva Blue
      91 Green “Mad Maxine” Festiva B6T
      93 Festiva GL Black BP automatic
      93 Festiva GL Green stock
        uhhh, do your door switches work? the buzzing is your door ajar warning. fix or disconnect the switches and that should solve your issue.
          I always disconnect the buzzer, drives me crazy
            I did notice the cap on the driver's door switch is missing exposing just the spring. I'm pretty sure it's been like that for a while now.
            Is that the only door switch location or is there one on the passenger's side and trunk?
            Also, is the buzzer switch plug under the plastic steering rack housing?
              one switch for each door, none for the hatch
                I thought the buzzer was just for the headlights?
                06 Jeep Cherokee Overland
                95 Aspire (sold)
                  There's two.
                  The headlights go "BEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE"
                  The doors go "BZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ"
                  both horribly annoying
                    if i just did the tach cluster swap I wouldnt get the other one then i assume.
                    95 Aspire (sold)
                      Wow I've never heard a door buzzer, but then again my door switches are stuck in the closed position:p
                        About the headlight beep, whenever i turn my car off it has the sound of an EKG flat lining. The thought of my car dying makes me sad. Good thing its no where close to dying!
                        95 Aspire (sold)
                          Got it. It's a wire with a clip under the steering column. If you move the vent out if your way you can get to it easier.
