My Weber has not been running well with the cold weather. Chokes, for some reason are "mysterious" to me ...somewhat.
Car is down in MPG's, and after running on the highway, and getting off at an exit, rpm's drop WAY down, and the car wants to die. After a few minutes of running on street speeds, it starts to run more normally.
Doing a little troubleshooting, I have (with engine off) kicked the throttle and watched the choke flaps shut as they should, and watched the flaps open as it warms. (good operation)
I checked voltage to the choke, and am only getting 7.11/7.12 volts at choke wire. Choke wire is still from orig, location at the alt. Should be 12V
Anyone have any idea what is going on?
I had orig. adjusted it in summer, at install, 1 1/2 yr ago, and all was good last winter. This just started this winter. Any help is appreciated, and Thanks in advance!
Dan
Dan
so I have been kinda putting it off. Wanting to do the 60-70 amp alt while i'm at it.
