will a 95 aspire 1.3 fit a 93 festiva
  • will a 95 aspire 1.3 fit a 93 festiva
    I need to know if a 95 aspire 1.3 will bolt right in to a 93 festiva and do I need to swap the computer?
    Goes right in. Just use the intake manifold from your 93. And you won't need to swap any of the electronics.
      Thanks.
        Not a problem.
          Which intake gasket should I order, the 95 Aspire or the 93 Festiva?
            They are the same. So, which ever one is cheaper.
              Ok, thanks.
