Maybe you turbo guys can give an idea where else to go with this issue. For starters I have a 92 sohc b6 with custom manifold and a DSM t25 turbo. I installed the turbo used with aprox, 70k on it. No shaft play to speak of other than typical oil clearance. Ran it hard for about a month and it slowly started smoking on decel after hitting boost. I assumed it was my catch can getting pressueized and blowing oil vapor back into the intake. So I installed a check valve. No change. Next I rebuilt the turbo, first time boosting, same thing. So then I bought a "360 staggered type" exhaust side seal. No change. I installed a oil restrictor banjo for the oil feed, it made it marginally better, then I changed the drain tube size to a larger hose. Again marginally better, but now only smokes after it gets warmed up to operating temp. Anyone have any other ideas?
oil smoke after boosting.
Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig -
Little bigger restrictor?
Edit: technically I think it would be a smaller restrictor to reduce pressure.1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
The smoke is definately light blue. I can clean out the intercooler, but the piping didst have ay spots to trap it.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
Maybe its not the turbo?
Intake valve seals? Vaccum is highest on Decel...Some people like to read fiction,I prefer to read repair manuals. Weird I know-
It did smoke a little while boosting. The valve seals were replaced about 30k ago.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
Dsm t25. I rebuilt it, still smoked, installed a -10 AN drain line and it stopped smoking. Atleast till the #4 rings went. Lol now I'm in the process of rebuilding the bottom end. While it held it was full 14lbs at 2900.Last edited by gauge_half_inch; 08-28-2012, 04:44 PM.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
