tried searching but came up with nothing ,,, how do you take out the 2 side dash vents ?? look like they would break if you tried to pry them so I thought I would ask the pros first.
dash vent removal
He's asking about the vents on the ends of the dash, near the driver and passenger doors.Originally posted by rockin86ranger View PostBFH and Sharp chisel! Idk which vents you're talking about so i can't really help, sorry. Guess i could go pull the dash out of the trunk of my Taurus and look but that sounds like work.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
with a screw driver.......:pOriginally posted by william View Postyep thanks guys ill have to check it out tomorrow .....whats the best way to get to that screw"FLTG4LIFE" @FINALLEVEL , "PBH"
Just get under there and look around; might be easy, might not.Originally posted by william View Postyep thanks guys ill have to check it out tomorrow .....whats the best way to get to that screw90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
It's only easy if the dash is out. Here is a pic of the vent from behind the dash. The ductwork (which goes directly in front of the screw) has been removed for clarity. Good luck.Last edited by bravekozak; 02-05-2012, 12:47 PM.
