AC compressor
  • AC compressor
    So how do I know if my A/C compressor is bad or of the clutch is just locked up on it? I was noticing the clutch kit on FSM for just $10. I don't want to go that route unless I know thats it though.
    1993 Festiva GL The Besty Festy
    A quick check is which part is locked up ? The center hub should turn, the belt
    part should also turn. If the hub is still turning you have a chance, take it
    apart and check it.
      alrght I know the belt pulley is locked but i haven' pulled it and checked the hub or anything.
        So I checked it today the pulley is stuck but the center still turns freely. So is the FMS compressor clutch what I need?
          come on anyone got an answer for me?
            That FMS kit contains the parts you need to replace.
