Have heat out of the left floor and left defrost but none out of right side blows cool air the heater hoses running to the core the one on the passenger side is hot the drivers side is cool when I drive it is when it works like this otherwise I get cool air out of it when I sit at idle
heat issue
^ You still need to work on your grammar a bit, but other than that, you're better than most.Trees aren't kind to me...
i re-read it 3 times, but i think i have an idea what's going on here.
XCRACER, you have a clogged heater core, you need to backflush it.Trees aren't kind to me...
both, untill it easly flows the same in either direction. then while you're at it, flush the rest of the system and fill with new fluid.Trees aren't kind to me...
Originally posted by FestYboy View Posti re-read it 3 times, but i think i have an idea what's going on here.
Thankfully, I'm not the only one! It's very confusing!
Ibetgrammarpunctuationandclaritywouldhelpthisposta lot!www.cardomain.com/id/jermnc77
Madness Committee Member & Contact Person
www.festivamadness.com
Festiva Madness
Snoopy's
4621 Atlantic Ave
Raleigh, NC 27604
No heat in car. Engine warms up like normal.
Unhook both heater hoses.
Flush water through one hose
Switch heater hoses and flush the other direction
repeat direction switching until water flows freely
Use water hose and sprayer like to spray off engine.
Pull thermostat and lower radiator hose.
Flush water in all directions possible until
water comes out clean.
Assemble with new parts as desired.
fill with 50% water and undiluted coolant.
Burp air..test, enjoy !!
