just did LCA's , t\tie rod ends and sway bar bushings, the shake is gone,
I have a little pull to the left on test drive, i took a level and my drivers side was toed in at the bottom, I know how to adjust for this but I was wondering are there any other adjustments that are needed ???
also I didnt torque the bolts for the sway bar bushing to factory, It seemed that they were not gonna get there (47 to 57 ft lbs) should I give it another go ????
