They have a kit with just the boot for $5 and a new caliper would run $24. I don't think it's leaking.. although if I pull the cover back brake cleaner runs out in a orangish color. Should I replace the whole caliper or just the boots. This would be the first time working on drum's. 91 stiva btw
Torn rear wheel cylinder boot
The orange is rust, I think you will find them full of corrosion, I used to reseal them all the time, but I'm a cheap bastard. :lol:97 Ford Aspire 2dr 5 sp
92 Isuzu Impulse 1.8 5 sp 140HP, handling by Lotus, balls by Isuzu.
95 Mitsubishi Expo 2.4
http://img.photobucket.com/albums/v2...64/xsext2a.jpg
Dad normally likes to be cheap.. I just told him this would be the best since he drives a 2-lane road everyday with no curbs. They were 14.52 a piece from rockauto.. also ordered the o2 sensor 16ish. All together with new outer wheel bearings and new stake nut and seals... somebody really didn't know what they were doing the last time they were repacked.. $115. In a way he's kinda wondering if it's worth it.. but I told him if he bought another car he'd just have to do the same. He should be able to get another 200k out of it.. if I could only get him to take care of it.91 rusty Festiva 260k
There are lower control arms on Ebay right now.97 Ford Aspire 2dr 5 sp
Yeah the one's on right now have you checked the shipping? A little on the high side.. coming from chicago to kc that doesn't make since. It will be in the fall when I replace them.. the aspire's are worse than the stiva's due to the years being pulled on all 4's behind a motorhome91 rusty Festiva 260k
So I have both new cylinders couple questions.. Can I replace the cylinder without removing the shoes. It looks like I might be able to, although it looks easier to just remove the shoe and be done with it. Next question.. Should I bleed the brakes after each side or just replace both and then bleed everything? My gut says do both then bleed.91 rusty Festiva 260k
