Hatch Squeak
  • Hatch Squeak
    Any tips on silencing the annoying squeak in the hatch? I have tried adjusting the latch but it seems to come back a short while later.
    wrap a small piece of electrical tape around the part of the catch that the latch hits. Use a piece about 3 or 4 " long. It will keep it quiet for a while. Lucky has the same issue.
    91 Festiva GL "Scrat"
    82 Honda Goldwing GL1100i
    85 BMW 535is "Brunhild"
      If I slam my hatch really hard it stops. I'll try the tape thing. I hate that stupid squeaking thing.
      93 Festiva L White B6T
      99 Dodge Ram STL Green Cummins. AKA the Jolly Green Giant
      89 Festiva Blue
      91 Green “Mad Maxine” Festiva B6T
      93 Festiva GL Black BP automatic
      93 Festiva GL Green stock
        turn the music up REALLY LOUD
        He said a bad word :nono:
        1990 Festiva
        1987 F-250 diesel-powered
        1984 Ironhead Chopper
        1999 Ducati Monster
          all purpose grease
          ADMIN @ http://ironjuggernauts.com/forum.php?referrerid=1
            It only squeaks when I have a passenger
            Thanks for the replies. Not too excited about slamming the hatch down. Would probably lose my spoiler... or cause more rattles. I will try some tape.
              If it stops by slamming move the catch slightly to the rear. Far enough where you don't have to slam but not so much that it rattles. Worked for mine.
                My hatch NEVER rattled until I read this thread last night. This morning after I started my car, the idle rattled it! I swear, once you get an idea in your head it happens...
                -Zack
                  My car runs smoother and quieter after I've had a couple of drinks.
                    My hatch almost drove me insane on my trip to and from madness. The electrical tape trick works for a little while, you can also steal the longer hatch rubber pads ( little circle rubber things that buffer the hatch when closed) from a parts car and replace the short ones with longer ones. It helps but doesn't cure the problem. Having stiff suspension, stiff engine mounts and no interior or radio makes this problem especially annoying. I'm going to design my own latch catch that fixes it once and for all.
                      Tighten up Charlie!
                      1989 Ford Mustang GT 5.slow
                      1996 Ford F-150
