ive owned the car for a couple months now and always had to run the fan on high because the heat absolutely sucks. but now the fan barely works all of a sudden. i thought it wasnt working at all and had it on fresh air just to get some sort of heat flowing. Today I noticed when it was running but just sitting there i turned the blower on high and felt a little bit of air coming from the defroster vents. (very little) could it be just the switch? or more than likely the blower itself or something else?
blower motor or switch? 91 festy
be sure that the blower intake isn't blocked, and if the blower has only one speed, the resistor is also faulty.Trees aren't kind to me...
sounds like the motor finaly gave out. make sure you still have power to the motor in Hi, then replace the resistor pack AND motor.Trees aren't kind to me...
