I have noticed a slight roaring noise when driving now. Thought it was my old tires (they were about worn out) had them replaced but noise still there. Noise does go away when steering wheel is turned slightly to the left, but not when turned to the right. Had the car on jack stands and check rear wheels, did not appear to have any noise or play in them. jacked up front end and place on jack stand, ran the car on the stands and could not hear any noise from the front either. At a loss right now on what it may be, any ideas would be helpful Thanks.
road noise when driving
Have to second the rear bearing as the culprit.
But should have detected some play.
Spinning up the front tires even with bad bearings will not produce a noise because you have no load on them.
Also, if you decide to do the rear bearing and this is your only car, get the bearings first, because if the bearings have failed you may not get it back together to drive it to the Mcparts store.
This is the voice of experience!
Only other advice is to use Timkin bearings.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Try shoving and pulling on top of back wheel to check for worn bearing play. Relase parking brake to avoid confusing brake noise with bearing play.
bearing job photos http://www.photobucket.com/Festiva-backwheel to save you searchingLast edited by WmWatt; 02-21-2012, 11:28 AM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
