Fuel pump?
  • Fuel pump?
    What all mechanical fuel pumps will fit on an 89 festiva? What brands of cars?
    89 Festiva. carby. needs repairs!!
    First time owner
    89 L carb'd - white / still needs work
    Bought for mpg and only paid $250
    What's the matter with putting the right one on?
      Rock Auto $21.79
      They ship to TX
        Mine is leaking. And I need one NOW
        First time owner
          Most parts places should be able to get one overnight.
          I just checked and our napa has them in stock.
            If this is some sort of emergency and the stock one is not available
            today, most stores should have a Mr gasket 12s and a block off plate.
            Also, if this is an emergency do not get in a hurry and create a 2nd
            emergency! Be safe with fuel.
              What do you mean block off plate?
              what good would it do?
              First time owner
                Geeze chill man! Go out & shoot a wild hog!! Do what econo said, check local parts stores. Overnight may cost a little more but you'll have it by tomarrow.
                '93 Green L - ' Tiva
                  if you add an electric pump such as the 12s it is not the greatest to
                  leave your mechanical pump on the engine so a plate is needed to
                  block where it was.
                  of course the best is call around and find the correct original part
                  for your car, change the fuel filters and inspect hoses ect while you
                  are there..do it right above all and be safe..
                    Sorry. I didn't mean to sound rude. I didn't know what 12s were or what was being talked about.. plus I've been sitting in the e'er car for 6 hours waiting on a ride.
                    First time owner
                      You only have one Festy tagged? And it's a carby?
                        Dallas TX NAPA shows 1 Bosch ($21.79) at their warehouse. The can usually have things next day if ordered before 2. I don't know of any other cars that would fit it...
                        No festiva for me ATM...
                          See what I say young Buck $21.79 Getcha Sum ! :p
                            I replaced mine. New from Canadian Tire cost $37 at the time. Simple bolt on job, easy access.
                              I've replaced this one earlier this year. It just sucks. Because this one just has a little pin hole in the top of it where the air box rubbed it.
                              First time owner
