Originally posted by stonemaster
brake rotors
my bad it aintOriginally posted by georgeb View PostAre you saying that your rotor and hub is one piece?Last edited by stonemaster; 02-23-2012, 06:18 AM.He said a bad word :nono:
1990 Festiva
1987 F-250 diesel-powered
1984 Ironhead Chopper
1999 Ducati Monster
Yup that's correct, but you can get the hub out of the knuckle while it's still on the car
could u give me some tips, i guessing some sort of puller is neccessaryOriginally posted by Damkid View PostYup that's correct, but you can get the hub out of the knuckle while it's still on the carHe said a bad word :nono:
1990 Festiva
1999 Ducati Monster
we have one at my shop but it SUCKS and i wouldn't use it on any car. takes forever to set up and we have to bits for it to boot!.Originally posted by Movin View PostYes, excellent results. The non-direction finish is a nice plus too.Trees aren't kind to me...
Its nice having the rotor turned true to the hub as well. The other way will
almost always have a little lateral run out no matter how much you clean
mating surfaces.
You are right, they take a little longer to set up but not more than a couple
minutes , unless you haven't thrown the directions away yet! The way
the manufacturer says to do it is nuts for production.Reflex paint by Langeman...Lifted...Tow Rig
A slide hammer will usually pull the hub/rotor out of the knuckle. Just make sure you don't get the bearing and races dirty and might as well put a little fresh grease in there while it's apart.
It's not the preferred method, as bearing damage can happen, but it works well enough the majority of the time.
oh, here's a big tip for you if you pull the hub from the knuckle (on or off the car):
Do NOT loose the spacer ring!!! and do NOT use it for the other side!!!!Trees aren't kind to me...
sorry I cant hear u, could u speak up a bitOriginally posted by FestYboy View Postoh, here's a big tip for you if you pull the hub from the knuckle (on or off the car):
and thanx guys, both the Honda and Subaru shops have the rotor lathe so i may go that route , but since i already got the parts I'll probably tear into myself,
thanx alot guys, and I mean it
any of u guys get up to the High Country I'm buying the first roundHe said a bad word :nono:
1990 Festiva
1999 Ducati Monster
