Ok the b6 is running good but today I heard a tick that sounds like hla tick only it seems a bit louder my question is could my performance cam cause something like this or is this just a typical hla noise and if so what should I do to fix it I pulled the valve cover and pushed down on the rocker arms and they all seemed ok so is there anything I can do aside from replacing the hlas
New development with the b6
These things are quite noisy! I have no performance cam experience but with my stock cars there always loud1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
it's not right if it doesn't sound like a sewing machineTrees aren't kind to me...
When you checked for loose or soft rockerarms/HLA's, did you make sure each rocker was down on the base circle of the cam?Brian
