I have been doing all kinds of repairs to our Clunkerball Run 990 Festiva. I replaced the water pump and put in new coolant. I started it and it took a while to heat up and the heater is blowing cold air inside the car. The top radiator hose is hot but the bottom one is cold. I checked the thermostat in boiling water and it opens fine. Also, there is a small leak from the passenger side hose going into the firewall and heater core. Any ideas Festiva Gurus?
Thanks,
Clunkerball Run
Thanks,
Clunkerball Run
