This is my first attempt at doing a fine lap job
I just curious as to how much lapping is necessary to get a good seal going. Once I got my suction cup to stick without slipping, I ended up with these results.
Should I do a little more lapping so that the seat is smooth all the way around? Or is this more or less where you want to be? I wasn't sure, and didn't want to grind the valve too far down since it was pretty smooth. Thanks fellas
