The carburetted '89 Festiva has been driven short distances all winter and the PCV valve is full of foam, also foam under the valve cover. The soot has been wiped off the spark plug tips. I plan to take the car out on the highway to burn off the foam. This is prior to the required emissions test.
Is there anything else really needed to clean up the engine or willl the high speed driving burn off the winter's deposits?
Thanks.
Thanks.
