Has anyone had the ball joint come out of the spindle while the pinch bolt is still in place? Made for quite the interesting that's for sure!
ball joint problems
Originally posted by whatle View PostI haven't had much time to look at it since the cops towed it away..... Might have to get that cheap set of lca s off Ebay I guess
careful now, you might regret thatsigpic
i haven't had issue with the stuff on ebay out of FL (yet). and if it lasts a year, it's STILL cheaper to replace with another set than going to the parts store. make sure your pinch bolt is grade 8 (metric 10.8 ) or greater.Trees aren't kind to me...
Pop it back in and it will be moveable. Not drivable but moveable.1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
the ball joint was a little loose before so im gonna wanna replace it regardless but i have to wait till tomorrow since i was 15 minutes late... they love keeping your car and charging you up the #%^!
I had to remove one once, that required spreading the pinch a little bit. I didn't QUITE get it tightened down enough, and it popped out. Put it back in, and REALLY tightened down. It lasted a couple more years until replacement time...
Someone else pointed out that the bolt can grind down, and it can. Bring another bolt for just i case,or, to get it out of the yard, spin the bolt around to have a good side facing the ball joint.Contact me for information about Festiva Madness!
