This car has been gagging and acting like its out of gas on and off, and has lost all spark more than several times. The code flash was the crank sensor, and the new distributor fixed the spark problem. We still have this gasping bucking and sputtering problem when its put under load.
Replacing parts doesn’t bother me, those are more new parts I don’t have to worry about later.
I'm running out of stuff to replace….. and its still doing it.
Please read the list of stuff I've put on and done, and post a comment or opinion, I'd greatly appreciate the input.
NEW;
>Distributor, coil, ignition module.
>Air filter, fuel filter.
>Plugs, wires, rotor & cap.
>Compression test; 150psi on all 4. A yr ago it was 170 on all 4.
>Good hot blue spark on all 4 plugs, arcs 2" in a spark tester.
>Fuel pump sock clean.
>Gas tank checked, no water. I put a bottle of dry gas in for kicks.
I tried this with the fuel system;
>Fuel pressure regulator, if you disconnect the manifold vac line and plug the manifold end, it will run OK in 1st gear, 2nd gear.(under load) 3rd gear only if it is not under load [cruising] 4th and 5th gear acts like it is starved for gas.
Plug it back in, you cant get anywhere even in 1st gear, it acts like its out of gas, sputter gag choke surge up down ect ect.
> Clamping the fuel pressure regulator return line off makes the engine barely run at all.
since I did that, now it wont run worth a damn even if you plug the vac line on the FPR.
>With everything hooked up "correctly" the Engine will start easy, idle smoothly. Rpms can be raised normally providing you don't "gun" the throttle, if you do it will bog out.... but wont stall.
>The only thing left in my head to replace is the fuel pressure regulator, the fuel pump, and the injectors.
>I plan to do a leak down test once I fix the tester in a day or 2.
I'm ready to set it on fire….. any suggestions what to try next?
NEW;
