Ok, so i re-installed my gas tank with fresh gas and my fuel pump. Tried to start it and sounds like it wants to but not catching. I was told to test the fuel injectors but im not sure about how to do that yet as i am still learning about my festy.
How do i test the fuel injectors?
Is there a type of tester needed?
If fuel is getting the the hose that connects to the fuel injectors, but not coming out of F. I. themselves what should i do?
If they are "clogged" is there a way to fix it?
Thank you all in advance for the advice.
