... and more importantly how can i keep it from getting out again? Picked up a broken stock trans from Jerry the other day to fix for FestEvil (88Ls need 5speeds too
) He and i assumed it had a bad shift gate since it first wouldn't go into all the gears that go "up" in the pattern (1st 3rd 5th) and then it got stuck in fourth. Took it apart this morning and found that the shift gate was fine, it was just that the magnet got out of it's retainer on the bottom of the case and magneted itself to the shift gate blocking movement. Anyone know a good way to make sure that magnet stays down there? Nothing appears broken anywhere, just that the magnet somehow found a way out of it's cage.
Still concerning that it came out in the first place though. Oh well, at least I should have a good trans by the end of the day!
