car stalls when i come to complete stop
  • car stalls when i come to complete stop
    also when i put it in gear from park it stalls. any suggestions? b13 automatic tranny
    Vacuum lines is my guess
    Does it stall when u apply the brakes?
    -M3NTAL MARK! Woo!!
      What year? What fuel system?
        no when i push brakes its fine until i put it in gear or come to complete stop.
          90 fuel injected
            Try cleaning your IAC and MAF also
            -M3NTAL MARK! Woo!!
              As a band-aid you can turn up the idle screw under the rubber plug. I did that to mine until I can fix the compression issue.
                Have you replaced the O2 sensor? Try it.
                '93 Green L - ' Tiva
                  Blow out all of your vacuum lines. Check your fuel.
                  1989 Ford Mustang GT 5.slow
                  1996 Ford F-150
                    that sounds like the new fuel cut for mpgs lol shuts off at stops but starts once your ready to go...
                    1991 stiva.
                      will try all of this thanx for the help!
                        The motor moves a little and opens the air leak in your intake
                        tube between the throttle body and the air filter/VAF
