Hello there folks, i have a question. I have a bp install with a G-series tranny and a spec clutch. I cant seem to figure out why the rpm drops when i step on the clutch but would slowly creep up to 900 rpm. I hope one of the experts could help. Thanks!
Festiva drops the rpm when clutch is push down?
Mine does the same thing untill it gets hot.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
load compensation.... the rotating mass of the gears helps keep things spinning and when you depress the clutch, that mass becmes uncoupled and your IAC isn't fast enough to compensate.Trees aren't kind to me...
mine did the same thing and i had an auto ECU....1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
