car
  • car
    can anybody tell me why my festy cuts off when it gets warmed up?its crazy need help
    Moved to the proper section
      Need more info:
      FI or carbed?
      Any other work done to it?
      Any other problems?
      What have you looked at already?
      More detail. Does it cut off when you push the acclerator or just cuts off on its own? Etc.
      Karl
        car
        its a carb car it cuts off on its own dont know what it could be most of time when shift light comes on car wont start if it runs when shift comes on car cuts off
          Was it like that when you got it or was it running okay until this issue?
            car
            it was running great til this started
              Look at the rubber fuel line that goes INTO the fuel filter, at the bottom of the firewall on the drivers side. There is a metal fuel line that runs under the body of the car, from the tank. The rubber fuel line (about 4 inches long) that connects the metal line to the fuel filter, has to make a sharp turn to reach the fuel filter, and since the mechanical fuel pump on a carbed car, mounted on the engine block, pulls fuel through the fuel line, it creats a vacuum on the fuel line. With age the rubber fuel line gets soft, and can collapse from this vacuum, shutting off fuel to the filter and the fuel pump.
              It happened to me, and a few others here. It will just shutoff. Later it will run after the vacuum bleeds off, and then while driving it will shut off again. Look for that rubber fuel line and see if it has a sort of kink in it, where it bends up to reach the filter. I replaced mine with new fuel line, about a foot long.
              Hope this helps.
              Dan
