Loose vacuum hoses part identify
  • Loose vacuum hoses part identify
    While working under the car on my oil pan. I noticed a loose hose under the Carb area. It connected to a cylinder looking thing. Looked broke off. The other end of hose connected to some split lines. The part I need identified had two similar cylinder looking things with like a rubbery round thing on the end.
    These parts are not seen from above the engine. And way away from the ground.
    If I HAVE to I can get back under there and SEE if I can get a good enough picture for you guys.
    89 Festiva. carby. needs repairs!!
    First time owner
    89 L carb'd - white / still needs work
    Bought for mpg and only paid $250
    I would just take the part off but I'm unsure how it connects. The hose looks to have a broken plastic piece in it.
    First time owner
      Does the hose have an identifying colour? Often a dashed line along its length.
        If it doesn't rain tomorrow. I'll climb under there and look and try to get good pics.
        First time owner
          The best picture I could get.
          First time owner
            It's underneath. And it as 2 hoes on it and connects to a metal hose.
            First time owner
              its one of the thermo sensors. Just need to know if its the white one or the blue one that is broken?
              91 Festiva GL "Scrat"
              82 Honda Goldwing GL1100i
              85 BMW 535is "Brunhild"
                It's the one on the driver side and the hose is the one closest to the driver side of car. Hope that helps like I side it's really hard to see it because it's far away, dark and dirty
                First time owner
                  I took this photo of the posterior hoses, inferior view, carburetted engine. The scarlet object is the oil filtre and indicates front (anterior) of engine. Photo does not show blue plastic object but I'll attach it anyway for future reference, and because I want to try attaching a photo to a message which I haven't done before.
                    Yes that's a better picture.!! The little hose connector that is broke is the one on the far left of your picture. Thanks for the picture!!!
                    what's this hose part and hose do? How do I find new part?
                    First time owner
                      I don't know if a new one can be purchased? However you can get one off another parts carby car or I may have one around.
                        How does this part connect. Does it just screw in? What does it control? Like what's it purpose.
                        First time owner
                          screws into intake, runs vacuum based on temp for the feedback system.
                            If I can't order it , I'll just have to see about finding one. Good luck with that. Lol.
                            First time owner
                              well if you don't I may have an extra 1,2,3 or more around.
