Just wondering if you guys know if an A/C compressor off a '97 Aspire will fit my '93 Festy.
Festy V Aspire A/C is it the same?
As long as you have the bracket for the Aspire one it will bolt up, but at least on the '93 I had the compressor was a V belt, not a ribbed belt like the aspire compressor. So you would need the crank pulley from the Aspire as well as the ribbed tensioner. Also I believe the lines have a different flange on them on the compressor end.No festiva for me ATM...
