dim warning lights on, car off?:help:
  • dim warning lights on, car off?:help:
    I have an 89 festi and when i shut the hot rod off, my oil light comes on very faintly and when i set my e brake, it does the same. i'm wondering why and if it may have anything to do with battery dying after 2 days of sitting? anyone have ideas?:help:
    Sounds like maybe a short in some wires.
    89 Festiva. carby. needs repairs!!
    First time owner
    89 L carb'd - white / still needs work
    Bought for mpg and only paid $250
      you think there is a relation between the two lights somewhere. i'm new to the festi and still learning my way around it.
        I'm only a year into festy. I haven't looked close enough at the wiring to know. But I believe the wiring are the same on the back of the dash. Possibly in the fuse box also.
        First time owner
          right on, guess i'll try the old fashion method of tracing the wires out and look for anything fishey...
            Check all fuses and grounds. Most likely a corroded ground causing an open loop battery drain on your system. You can check for a parasitic load by using a tester. Hook up positive terminal unhook negative terminal, put the tester on amps and hook between the negative cable to the car and the negative side of the battery. If there is a draw you will see it.
            1989 Ford Mustang GT 5.slow
            1996 Ford F-150
              Unhook all the wires from the alternator and re-try it.
                i did do all that except i only unhooked the main wire from the alternator and got a draw even with the fuses al out... i'll try unhooking the harness from the alt also. i might just have to live with it. thanks, also, what everyones favorite place to get parts for these little rockets?
                  The bigger of the two little plugs is the one I really was directing you to.
                  Parts totally depends on what part..metal is metal so pick and pull works well.
                  Reman, you want best quality,best warranty and parts store crew in your area.
                  New chinese and rebuilt domestic at the same store?? I would go with domestic
                  parts. Oreilly's is hard to beat for small towns.
                    thanks, lot of good info on this site... keeps a guy reading a while...
                      Welcome here, and good to see another from the west side of things!
