:?: So I'm piecing back to gether front hub assemblies for my Aspire brake upgrade and I got to the stake nut. Now it's kinda weird cause when I tighten it down onto the axle end the nut screws past or below the stake groove leaving no place to stake the nut. My question is...do I need some kind of spacer or washer to keep that nut up around that groove? And I don't have a torque wrench, so how do I know how much to tighten it down :?:
Stake nut woes
front stake nuts
For staking the front nuts, I found that a 2' bolt cutter tool works perfectly; put one tip in the dimple in the center of the axle, the other on the stake nut, and gently squeeze a little.
This doesn't work on the thinner rear stake nuts.88L black, dailydriver
88LX silver a/c, dailydriver
4 88/89 disassembled
91L green
91GL aqua pwrsteer
92GL red a/c reardmg
1952 Cessna170B floatplane
