I have 93 festiva/auto, and i'm swapping out the motor and trans. from a 90 festiva/manual. I just have a few questions to wrap this project up.
1: Do i need the ecu from the 90 to put in the 93?
2: No wire plugs under dash for the 2 switchs on the clutch pedal assembly from the 90, what do I need to do?
3: What do i do about the 2 sensors on the manual trans.?
Any help is greatly appreciated thanks!
Not a complete fix, but it will at least get the car going so you're not dead in the water. Sort the other switches out as you go along
