Hi,
So I put another BP engine in my white festiva. The idle is running rough. After you drive it for a bit and slow your car down to a stop the idle rests around 1500rpm then in 8 seconds drops to 550rpm.
Also we de-accelerating it backfires, not alot but it does...
Finally the check engine light comes on. It comes on after 15-20 minutes of driving. Nothing seems to change when it comes on. It brings up two codes. Codes #2 and #15. From what I know code #15 means poor signal to the oxygen sensor. I did repair that yesterday but I did not reset the ECU yet so the code keeps coming up. From research online, code #2 is supposed to be: IDM or CP Sensor. I have NO clue what either of those are.
Any idea of what's going on? Should I still try to replace the O2 sensor? (I believe that sensor was replaced 40,000km ago.
Also I did move the VAF around as I know those are finicky but that did not seem to change the strange idle behavior.
ideas??
ideas??
