What if I plug my PCV?
  • What if I plug my PCV?
    What will happen If I plug my pcv hose from the carb and install an oil catch can to the valve cover and road draft the catch can ?
    I have been driving the 89 but the blow by is misting my engine compartment
    with oil .
    1 tank of fuel and the oil is down 1/2 quart,smoking only at start up and after long decelerations .
    I think that the Seafoam has helped the rings come back a little.
    I want to overhaul an engine I found in a 323 , but I need the Festiva till I"m ready to swap out the engine.
    Donn
    ______________
    93 Blue rio/aspire swapped,B8,
    do NOT plug the PCV. hav you inspected it for proper function? you may just need a new one.
      It sucks oil into engine with PCV hooked up (after severe overheat and repair )from blow by and smokes badly
      Donn
      ______________
        pcv isnt the issue, it's your rings. a catch can is a band-aid, and still requires the use of a pcv.
          When my blow-by got pretty bad, I just took the PCV valve out and vented the valve cover to a catch can, then dropped a draft tube down under the car. Basically, just let it breathe to the atmosphere. Last resort type of deal. I was amazed at the amount of oil the ebay catch can would collect. Only bad part was the oil mist that would completely cover the rear hatch window, LOL. It did manage to get me another month of driving though, along with helping prevent rust on the chassis.
            Thanks blkfordsedan thats exactly what I"m thinking .
            I know the rings are bad! but Im going to put the money in the 1.6 engine and dich the 1.3l so I have some time to overhaul the 1.6 and still use the car at the same time .
            Donn
            ______________
              Before PCV valves were invented the crankcase vent would empty into the atmoshpere. All you are doing is adding to the pollution in your area by spraying oil instead of smoke.
              You should have less carbon buildup in the engine you plan to scrap.
                FestYboy is right.....the engine really needs some type of PCV if possible. The only reason I did away with my PCV is because my car was EFI and it was blowing so much oil into the air intake that I couldn't drive 50 miles home from work without stopping to empty the oil out of the VAF meter, LOL.
