for some reason when i turn my lights on or especially when i use my cig lighter it blows my tailight fuse. it used to be only a once in a great while occurance but the last couple days, ever since i put in my escort center console it blows them as soon as i turn on my lights. ive looked and looked and the only thing i can find is a ground wire that is located right next the the latch to pop the hood has been cut somehow, i cant find the other end of it can someone tell me what that leads to... if thats not it idk what else it could be
blowing tailight fuses
That circuit is shorted to ground causing the fuse to blow. Probably a wire thats chaffed and rubbing on bare metal somewhere like the column or inside the dash. Since you mentioned it became a solid issue when you installed your console I would start there and look around for any exposed wires rubbing maybe behind the or unde the radio or under the drivers side of the dashTim
'97 Aspire ST, UltraViolet Blue, 37k miles - New Storage Queen
'03 SVT Lightning, Dark Shadow Gray, 30k miles - Storage Queen 11 months/year
'95 SVT Aspire B3T, Green Mica, 75k miles - DD
'01 ZX-500R, Violet Pearl/Gray, 5400 miles - Storage Queen
'89 Suzuki FA50 Bright Red - Lake Transportation
Cardomain.com/id/aspiresvt
Previous Vehicles
'92 Festiva L "Sport" Green Mica
'92 Festiva GL Blue Pearl
'92 Capri XR2 Performance Red
I've had a bad bulb do the same thing too. maybe look into the light for the cig. lighter, maybe that bulb is finally gone but didn't blow the filament completely.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
that I don't know. Check your tail light bulbs too, perhaps just unhook them for kicks and see if it makes a difference. I had to re-install one bulb at a time till I found the culprit.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
that wire near the hatch latch has to be grounded, so you have to find that wire!! start with the driver side harness.Trees aren't kind to me...
