two quick easy questions
  • two quick easy questions
    first of all im about to get a new air filter, any recomendations? kinda like everybody recomends the denso o2 sensor. which i just bought to btw.
    secondly ive did some searching but was still a little confused sry. but my cooling fan stays on all the time. i pulled the sensor outta the tsat housing cleaned it up really good, didnt help. i tried grounding the wire that plugs into that same sensor and the fan shut off. so heres what im unsure about. does that mean the tsat sensor is bad or the relay i read about that im not sure where its at. where to go from here?
    93 L plus 5 speed, custom herculined paint job, custom billet grille
    Didn't mean to bump your questions down. Lol
      easy questions
      fan relay is shot if it stays on all the time. get a K&N air filter # 332222. i just got one yesterday. its not for a festy,but its the same size .
        Yep on the K&N 332222! Alittle expensive, but you'll only buy one ever.
        '93 Green L - ' Tiva
          If the fan turns off when you ground the wire on the t-stat the faulty item is the one you are bypassing which is the t-stat sw.
            That's the same thing they said about Windows 95 computers..
            2008 Kia Rio- new beater
            1993 Festiva- Fiona, DD
            1997 Aspire- Babyspire, DD
            1994 Aspire - Project Kiazord
            1994 Aspire- Crustyspire, RIP
              wrong!! GeorgeB has it right, the issue is an open thermostatic switch (needs replaced). it acts as a ground for a normaly open relay switch.
              I coulda sworn I said something about you putting up wrong information, windy1. Stop it.
                Yep. it's the sensor. I think they're about 35.00. First part I ever replaced on mine after I got it about 6 years ago. I've almost replaced the rest of the car by now lol.
                  where can i buy one at i checked ebay couldnt find one.
                    68% of all Internet info is heresay and/or made up.
                    BTW, OP, your tstat switch needs to be replaced. Buy it at Vato Zone or O'Reallys
                    1989 Carby L: Stock. Slow.
                    1998 Mustang Cobra: ported heads, cams, longtubes, 4.30 gears
                    2016 Focus ST: daily driven go-kart
                      Yes. this the second post today that he has supplied poor/bad/wrong info.
                      Understand Windy1, some people do not have the luxury of being a parts replacer. They have a limited budget and it falls to those supplying information here, to help them in the most economically expedient fashion possible.
                      Thus "diagnose then replace/repair".
                      No, you can't be banned for suppling poor/bad/wrong information.
                      But, I would not report someone who might label you a "poor source of repair information"!
