Ive been driving the 89 around and Ive always noticed its been a pooch at the top end but, decent on the low end. The guy I bought it from said it was from the 16 inch wheels and being an automatic which I figured was true. It would excelerate decent to about 55-65 and then it was forget it and 70 was tops 75 if the wind was pushing or going down hill.
Yesterday was 40mph head wind and she got up to her typical 55 or 60mph on the highway as always but, it was too the floor and not gaining and gear searching trying to hold the speed. When it would shift in to OD or 3rd it would just fall on its face then down shift. Each time the speed got lower and lower till I was only doing 35mph. Trans wasnt slipping and all fluid levels are fine. Any ideas? The only thing wrong with it is the valve cover gasket is leaking and I wondered if something got wet. I pulled plug wires off one at a time to see if there was a dead cylinder but thats not the case. What else can cause such a weird thing? Im guessing its electronic because it drove fine on the way to work in the morning but on the way home forget it, it was acting like a dog and would only pull 55. Any ideas or help would be nice.
Changed the Throttle position sensor with no change.
In the morning when I start it the engine usually has a very high idle.
