Ok I have this G series tranny apart, and I'm getting ready to put it back together, but I have a few questions..
1) is there any way to tell from looking at it/playing with the gearsets what kind of shape the clutches/synchros are in? I haven't ran this transmission yet, and don't even know what I'm looking at.
2) I replaced the input shaft seal and the outter race for the shaft bearing came out and went in a little too easy, it spins in the housing. Is this something I should be concerned with or just run it? The race on the other end, and the one for the secondary shaft in the case with the bell housing also spin.
3) I think everything is set to neutral, but when I turn any gear wether on the primary/secondary shaft or the ring gear itself, they all spin. Is that right for being in neutral?
