What size and thread pitch is lower strut bolt
  • What size and thread pitch is lower strut bolt
    Well, both bolts on my rear struts are frozen solid, and the drivers rear bolt head is totally rounded off. I was gonna try and remove the passenger side but it is also frozen. Does anybody know what size and thread pitch the lower rear strut bolt is? Thanks for your help.
    Semper Fi til I die!
    1993 Fescort GT 1.8 BP automatic Kia Rio front struts and cut springs Cut Front Festiva springs with Monroe Aspire struts in rear
    IIRC its 10x1.25. I had to buy a tap and tie to clean mine ip when I did mine.
    Early 99 F350 ex. cab longbox Powerstroke 6 spd, manual tranfer case and hubs 190k
    2009 ford flex
    2002 ford Ranger 4.0l, 6" lift, 35x12.50x15 super swampers
    1994 F150 4.9l, 5spd, 2wd
    1988 Festiva 1.3l, 4 spd, 184k
      Thanks Neb, I'll go check to see if its correct.
        Yep, when i had to replace my bolts I used M10 Size, 1.25 mm, 70 mm Length.
          Just what I needed ! Now I can buy some bolts ahead of time when I replace my shocks this weekend
