Boost at 5k
  • #16
    Message Eurotiva he can send u a pic of his boost leak detector it's home made.
    1989 Ford Mustang GT 5.slow
    1996 Ford F-150
    • #17
      I have a boost leak tester. I also welded the manifold. It turns out the engine has low compression in all cylinders.
      91 Festiva BP Autocross/Track/Rallycross hopeful
      14 C7 Z51
      • #18
        What's it reading?
        1996 Ford F-150
        • #19
          70-40-80-100 as opposed to 150-150-150-150 awhile ago
          14 C7 Z51
          • #20
            I'm thinking you lost some rings...well, a lot of rings actually
            • #21
              Bummer, just another reason to upgrade!!
              1991 blue L, 5 speed.
              1988 red L-plus-all stock.
              • #22
                Burnt up exhaust valves would do it, too. Make it run like crap and pop a bunch (fuel mix going down stream on compression stroke)
                1989 Carby L: Stock. Slow.
                1998 Mustang Cobra: ported heads, cams, longtubes, 4.30 gears
                2016 Focus ST: daily driven go-kart
                • #23
                  Time for a 350whp e85 build. Hint with e85 you don't have to spend on the engine
                  1993 GL 5 speed
                  • #24
                    Just thow a bp in it. You won't be disappointed
                    -Greg
                    Redneck Engineer
                    FOTY - '09
