Ignition coil recommendation
  • Ignition coil recommendation
    Need to replace my ignition coil and having trouble getting clear cut advice on what brand. I've heard good things about MSD which I can get immediately from the parts store in town or is there something better I could get online that would be worth the wait?
    OEM junk yard.
      Why?? Are you building or repairing ?
        Repairing. Its an 88 and the engine will rotate but will not start. I replaced the plugs/wires/cap/rotor. Tested the coil with a multimeter and the primary resistance was in the low range of acceptable ( according to Hayes manual ) but the secondary reads too high and there is no spark from the coil to distributor wire when i crank it. Going to replace the main three fuseable links and hose the distributor with brake cleaner from searching this site before I buy another coil as well as check the fuel pressure.
